Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I'm just telling you that I used stock ported 96" heads with MCR drilled, screwed in adaptor and then screwed in ACR so I didn't have to use the buttons.
If you can get 103 ACR heads for the same price then go hard.
Just trying to find the most cost effective and easy solution. I see a kit for $285 or the adapters alone for $135 on Ebay. Looks like heads runs around $200 or so also on Ebay. I didn't know if there was another vendor I wasn't seeing. I appreciate your input.
There are a couple nice sets on Ebay at the moment a bit cheaper, if those don't pan out I could be interested in taking a little road trip. I'm only about an hour north of you
buy a set of regular 103" ARC heads,their for sale all over,not hard to find.if you all ready have wet heads,or can get a killer deal on them,use them,they will bolt right on
