103 twin cam hydraulic tensioners. advice needed
Old 01-18-2019 | 01:38 PM
fjkpan's Avatar
fjkpan
6th Gear
Default 103 twin cam hydraulic tensioners. advice needed
I have a 2014 heritage with the 103 tc engine at 47,000 miles. I ride easy most of the time. I run mobile1 20x50 syn oil and change it every 5000 or less. I need advice concerning the cam chain tensioners. I live on a budget and have to do my own wrenching. I don't mine when needed but I keep getting told my folks at the local dealers that replacing the cam chain tensioner shoes on 2007+ models is not needed. they tell me the new shows don't wear out and cause issues like in 2006 and prior. I am looking to you folks that I feel I can trust to offer your advice and experiences with the new hydraulic tensioners. If I need to replace them it will be shoe replacement and not looking to go gear drive or other updrades. Please let me know your advice.
Old 01-19-2019 | 09:03 AM
Shadowbennie's Avatar
Shadowbennie
Originally Posted by fjkpan
I have a 2014 heritage with the 103 tc engine at 47,000 miles. I ride easy most of the time. I run mobile1 20x50 syn oil and change it every 5000 or less. I need advice concerning the cam chain tensioners. I live on a budget and have to do my own wrenching. I don't mine when needed but I keep getting told my folks at the local dealers that replacing the cam chain tensioner shoes on 2007+ models is not needed. they tell me the new shows don't wear out and cause issues like in 2006 and prior. I am looking to you folks that I feel I can trust to offer your advice and experiences with the new hydraulic tensioners. If I need to replace them it will be shoe replacement and not looking to go gear drive or other. Please let me know your advice.
Hey fjk,
I also have a Rushmore, 2015 RGS, with 48k on it. While the general consensus is that the tensioner shoes on the newer hydraulic style are better & are less prone to failure, the Indy mechanic I get my oil & tires from recommended that I at least take a look at them at around 50k, so that’s what I did. The outer shoe looks good, maybe only .015” of wear, but the advice I’ve received regarding the internals on these engines at this mileage isn’t that tensioner shoes are of concern, but rather the lifters & inner cam bearings are possible items of concern. I’ve had a few shops tell me that if my bike were their bike, that they wouldn’t put it back together without changing out the lifters & ICB’s as these components are prone to failure, which is an expensive chance to take.
so I’m in the midst of figuring out what cams to get since I’ll have it that far apart, might as well cam it.
my maintenance habits mirror yours, fwiw
Hopefully others who have more expertise than I will comment, but that’s just what I’ve been advised to do.
Old 01-19-2019 | 07:39 PM
djl's Avatar
djl
At 47K miles, it is worth a look. Having said that, once you have opened the cam chest, might as well pull the cam plate/pump, install a set of CYCO tensioners, swap inner cam bearings for a set of full compliment bearings and, if not interested in a cam upgrade, button the cam chest back up and call it a day. HD says service life for lifters, even back in the day of the "B" lifter, was 25K miles, so replacing the OEM lifters with a set of S&S standards would be a wise move. This will require a bit more work assuming you retain the OEM pushrods which would also be a good idea but all could be done on a Saturday in a few hours if all the parts and tools are in hand. Parts are not that expensive and you will know the cam chest is solid. Might as well check crank runout while at it.
Old 01-20-2019 | 05:48 AM
2013_FLHTK's Avatar
2013_FLHTK
Changed mine at 60,000 when I replaced the cams
Old 01-20-2019 | 06:11 AM
Hoginedgewood's Avatar
Hoginedgewood
I would suggest you research the rensioner in the primary, from what I know it's a ratcheting adjuster that tends to over tighten (hot and cold cycles) then puts excessive tension to the transmission output shaft and wears the output bearing (which is a cheap bearing that has plastic spacers between each ball bearing instead of more bearings) .
Old 01-20-2019 | 06:51 AM
roussfam's Avatar
roussfam
I keep getting told my folks at the local dealers that replacing the cam chain tensioner shoes on 2007+ models is not needed. they tell me the new shows don't wear out and cause issues like in 2006 and prior. I am looking to you folks that I feel I can trust.
I usually ignore what the dealer says and go by what strangers on the Internet tell me as well...
Old 01-21-2019 | 05:12 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
What djl said.
Scott
Old 02-24-2019 | 07:53 PM
Dave0176's Avatar
Dave0176
I bought the Zippers dual piston tensioners, just because. I pulled the motor apart at 30K for a 103 kit and cam change, there was barely any wear on the stock tensioner. I did replace the lifters with Hylift Johnsons and put the SE cam plate and oil pump, not needed, but......
pat_in_the_hat
02-18-2019 09:47 PM
joebedford
Engine Mechanical Topics
59
11-06-2016 08:36 PM
offbeatmammal
12-28-2015 10:26 PM
Rogue8Man
10-26-2014 06:08 AM
bruggy
Exhaust System Topics
106
03-20-2008 07:58 AM
Quick Reply: 103 twin cam hydraulic tensioners. advice needed
