What size throttle body?
Hi All,
Needed some input from the pros on here. I have a 2009 Street Bob and upgrading from 103 kit to 110 kit. I already have woods tw 8-6 cams in my bike and setting compression at 10.75. My heads already worked , ported etc. Regarding TB, I spoke with someone at Fuel Moto and they suggested for this setup I get a SE 58mm with 5.3 g/ps fuel injectors. Others says may be too much? I was also thinking of the HPI 55mm and updated injectors. Any thoughts would be appreciated.
Hi All,
Im looking to increase both hp & tq but more tq is what Im looking to achieve.
This is pretty much the answer. Would I maybe spring for the 55 or 58? Sure. My 107" great heads stops at guess what....120HP. The tuner who knows his chit said you could go bigger, but you'd gain a tiny fraction under the curve and a 5-8 HP at peak. So, other than dyno sheet bragging, I wouldn't know the difference.
