Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
And last but certainly not least, if the flow rate of the head cannot take advantage of the increased flow of a larger t/body, then very little gains will be witnessed.
Scott
