help identifying evo engine inner case numbers
Old 10-06-2018 | 10:56 PM
gypsyblue's Avatar
gypsyblue
5th Gear
Default help identifying evo engine inner case numbers
Just got an evo motor for a build. Can anyone tell me what these numbers are? Located on the inner case. We know its XLH883. But looking for the year and whatever other info is here. I've attached a pic. Thanks!
Old 10-06-2018 | 11:54 PM
mmesa005's Avatar
mmesa005
Go to eBay and search for 24534 less the "-98" and you will get the left-hand engine case for a Sportster. 24558 less the "-98" should give you the right-hand case. 24470 less the "-98" or "-XX" for another year will give you the complete left and right cases as an assembly.
gypsyblue (10-07-2018)
Old 10-07-2018 | 04:17 PM
grbrown's Avatar
grbrown
If there is a VIN on the outside of the crankcase, you will learn more. Those numbers relate to the bare unmachined casting, but may not be the part number for the finished crankcase, which could be something different. What sort of info are you looking for?
StevenJP
EVO
21
05-16-2018 01:12 PM
strange1
Engine Mechanical Topics
01-21-2017 05:12 AM
Old Man Ford
EVO
06-24-2015 07:57 AM
streetg131
Exhaust System Topics
03-01-2012 05:15 AM
mrbikeuk
07-05-2007 03:59 AM
Quick Reply: help identifying evo engine inner case numbers
