FM 110 KIT 777 What Throttle Body and Injector size?
guess it all depends what size the intakes on your heads are . usually over 100 hp are the larger injectors. I think the 58mm is 1.7 inches but Im not positive. so if u have the same size intake into the heads the transiton fit would be very smooth., if you have the larger intake on the heads with the small stock intake the velocity will slow down a bit as it expands into the larger opening. guess u need to find out who ever did your heads and what opening size they have
I talked to FM and Zippers and both are in agreement that stock inj and TB are fine until you get up around 120/125 hp, and have ported heads, then the 58mm and hi-flow inj will benefit. I am going to do a stage 4 soon, and I sold off the 58 mm and hi-flows to get some of my money back. I got a package deal from someone and kept the cams/pistons/heads to install on my 103.
old thread
I believe that I made a mistake by not going to a 58mm TB
especially with the 777 cam which is awesome but not a lower RPM cam by any means
I did the bigger fuel injectors and all the other good stuff
I left some on the table
All that money and time just do it right i guess
Everyone Have a great Labor Day weekend
old thread
