TC oil Pump alignment
The following 2 users liked this post by robarosa:
Campy Roadie (08-28-2018),
EarlB (08-28-2018)
EarlB (08-28-2018)
I will also give you this caution. The two holes in the engine case that have locating dowels on them will strip very, very easy. I never use a torque wrench on those two bolts. The locating dowels take up a couple of threads and aren't engaged as much as the others. I recommend putting threaded studs in those two holes and ARP nuts to secure them. I've got a thread around here somewhere on how to do it. One final note; keep the cam cover bolts and the cam plate bolts separate, they are not the same and using the longer ones can dent a lifter bore. That's a PITA.
Cue the poster who'll tell you he's never aligned a Twin Cam oil pump in thousands of re-builds, uses 3 In 1 oil instead motor oil and has 246,000 miles on his bike. This forum seems to have a lot of guys who're willing to give advice on something they've never done before. That can be confusing.
The following 5 users liked this post by Campy Roadie:
crazytown (03-11-2019),
EarlB (08-28-2018),
jockotwin (08-30-2018),
Kingglide549 (08-28-2018),
robarosa (08-28-2018)
The studs pictured above are 1/4"x20 - 1/4"x28; 1 1/2" long studs. The nuts are ARP 12-point black oxide nuts 1/4x28. I double nut the studs, red loctite (the 1/4"x20 part of the studs and put them into the doweled holes and let them dry over night. The next day I remove the double nuts and assemble the cam chest. I put the ARP nuts on with a little blue 243 loctite and only snug them tight by hand, the stud is doing the work supporting the plate. I do it in sequence until the nuts are snug and then I skip them and final torque the others. I get them from Summit Racing by the box as I do a lot of 99-06 tensioner shoe replacement (Cycos using the original spring tensioners).
Here are the alignment pins
https://www.georges-garage.com/produ...t-screws-pair/
EarlB (08-29-2018)
The following 2 users liked this post by Screamin beagle:
EarlB (08-29-2018)
