113 woods 9b power off?
I have a 91 FXR with a 113. 11:1 compression Woods 9B mik 45 carb singlefire nose cone ignition bassani RR fxr 2 into 1 pipe.Heads qhere done flowed larger intake . Bench flow was 280+ @28 seems Like I am missing some HP. Bike hits hard but doesn't carry. What do you guys think?
I know 130ft lbs is nothing to sneeze at but am I leaving ## on the table. Maybe different cam pipe or carb?
Hey Brad, I had a 9b in my 96" Evo with stage III heads that flowed 284 cfm and really didn't care for it.. it had the same curve as yours but hp was a little more consistent with the tq unlike yours... I took it out and went with a w8 and then back to my W6exp. A cam I had woods grind for me. Comes on early and stays late... But I'm running a Supertrapp and a G. I was running an E but went to the G not sure it was worth the upgrade to the G... The 45 should work well. If it didn't, I wouldn't think the torque would peak the way it does..
