Is there a difference between these two CVO 110 heads?
Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
is there a difference between these two heads. Or are they just different badges? I never noticed there was two until I saw two bikes side by side this weekend.
there would be no major differences,but there are different foundries that have cast 110 with minor differences,that said,there is a lot of inconsistancies in 110 heads (core shift,throat size,ect) what exactly do you need to know?
