Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I was unable to ride my beloved 06 FLHT for about 8 months and after getting her back in the wind I'm finding several seals that are less than 2 years old weeping some oil. Base gaskets, lifter blocks, primary cover, possibly crank position sensor and oil temp sensor. I made the mistake of not changing the oil before riding again but it was hard to justify seeing as about 500 miles before I had to park her I had done all fluids and it was in a garage in Texas where the weather isn't too bad. Anyways I was just wondering if there was anything I could do to rejuvenate the seals. I have a primary cover gasket so that ones easy but the base gaskets for the jugs are kinda a pita to replace lol
