Lifter Advice....
Old 06-07-2018, 05:19 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,471 Likes on 3,646 Posts
Default Lifter Advice....
Hey, I have a 98 FLSTF. The motor is stroked and very well built. I'm looking for a lifter that can handle higher rpm's with out collapsing... I just collapsed another lifter. This is my third time... I've been using S&S but they just can't handle high rpm's. I'm not trying to brag or anything like that. I just want reliability. S&S tells me that thier Evo lifters are only good to 6250 rpm... I would appreciate a little direction as to who makes a lifter that can handle it... Thanks..
Old 06-07-2018, 07:10 PM
Steve Cole's Avatar
Steve Cole
Steve Cole is online now
HD EFI Guru
Received 3,690 Likes on 1,671 Posts
Good luck on that quest. The problem is that the HD does not have a good record with any lifters lasting. We are down to two manufactures of lifters in the USA now, so they all come from one of the two of them regardless of who's name you buy them under. At one time both of these manufactures were the same company, but the company went BK and two different plants were purchase by two different groups.
Old 06-07-2018, 08:31 PM
98hotrodfatboy
So should I consider solids then. Or should I just not take it over 6k any more.. I had my rev limiter set to 6500 but it didn't kick in...
Old 06-07-2018, 10:33 PM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is online now
Sponsor
Received 1,637 Likes on 1,181 Posts
Talk to WFOLarry about his lifters... HyLift Johnson lifters
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
98hotrodfatboy (06-08-2018)
Old 06-08-2018, 05:18 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
I suspect that the S&S lifters with the limiters, would be the ticket.
You won't like the sound of a solid lifter in that Evo, as the aluminum engine will grow, and the steel pushrods not so much, creating noisey lash at full operating temps.
Scott
Old 06-08-2018, 06:30 AM
98hotrodfatboy
Scott
I thought about the noise and most likely will not be the fix. I have a set of limiters. I guess I could through them in. I'm Waiting for a return call from S&S. I spoke to them yesterday and tech department told me that they're lifters for The Evo's are only good to 6250. The thing that I don't get is that the rev limiter never cut in. I'm going to have to get with dynatek on that.. I didn't think that my rpm's were getting that high. I don't have a shift light and can't watch the tach when I'm doing a 1/4 mile hit like that... Just kinda shifting when I start to feel the fade of power. The build does jump up there very quickly..
Old 06-08-2018, 06:57 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
if the motor is for racing & going to see 6200+,solids are a no brainer
Old 06-08-2018, 07:01 AM
98hotrodfatboy
True that Kirby.... But it's a built daily driver as well... Do you know any one that makes a better lifter for the street? S&S are my current and always have been... This is the 3rd time I've had issues with the S&S at high rpm's....
Old 06-08-2018, 08:18 AM
TroubledWine's Avatar
TroubledWine
TroubledWine is offline
The best lifters on the market for turning 6500+ are called "Go buy a Hayabusa and don't even worry about changing the oil."
Ok, on a serious note, S&S Premiums with limiters or just get it over with and go solid as others have suggested. Good luck man.
Old 06-08-2018, 10:49 AM
Mattbastard's Avatar
Mattbastard
Mattbastard is offline
Received 1,415 Likes on 866 Posts
I bought the Hylift Johnson's (direct from them) in the Slow Leak variety since I've got some taught 600 lift springs.
Be advised, they recommend running a LOT less preload than the forum implies you should. I'm told, from them, between 40 and 60 thou. I run 75 thou and they're quiet as a church mouse.
Quick Reply: Lifter Advice....
