Worth it to do TB/injectors on 107?
Stock bottom end, 107 kit, FM Level B heads, Wood 999-6a cams, D&D Fat Cat, Power Vision tuner, tuned on a SuperFlow dyno made 110rwhp/121rwtq. Haven't had it on a Dynojet in 6th gear yet for that TRUE number LOL. Drives like a dream, gets over 40mpg, etc.
What are the pros/cons going to a bigger TB(HPI) and/or injectors? Is it worth the price of admission on the road(power, driveability, throttle response, etc.) or is it not worth the trouble on a mild 107 build?
Scott
I have the same setup as you except the heads (ported by dan vance), the exhaust (V&H pro pipe) and the 50mm screamin eagle TB
Loaded base map from FM plus 5-6 autotune sessions with target tune and the bike made 118hp 126tq (not a dynojet dyno) and looking at the dyno graph there's still some torque left on the table (no HD tuners in spain, at all)
