Fueling Camplate 8015/8033 Question
Multiple times doing cams, but first time possibly going with an aftermarket camplate. I was considering getting a 8015 camplate and one of the oil pumps that go with it(7060 or 7062) and I was reading through the installation instructions: (http://www.feulingparts.com/feulingi...tions/8015.pdf)
Step 11....am I reading that correctly? It doesn't use bearings?
The 8015 even says, "The 7075 increases the strength and hardness of the camplate, holding tighter tolerances under temperature eliminating flexing and the need for bronze bushings as 7075 material has excellent bearing like properties."
So I guess my question is how does that even work?
martin10
Engine Mechanical Topics
09-18-2015 06:42 AM
StrokedNBored
07-24-2009 08:22 AM
