Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Looks like a solid 107-117 build cam at 10.5-11 comp. Knowing his stuff the torque will be early and often and a nasty idle with those asymmetrical lobes
Those were suggested to me by the man testing them as an alternative to the T-Man .625's I have in my 107. He thought mine was a little soft on the bottom end. Very interested in how this turns out.
If you have any questions or would like to order contact Daren Sheffer Call (812)-401-8863 or you can hit him up through facebook, always quick to answer and a great guy to talk to
Give Sheffer Performance a call He does a lot Cyclerama Cams .. He's in Evansville In , One of the best around!! You can also find him on Facebook. or Call @ 812-401-8863
