Recipe for torque
Old 09-26-2017, 08:40 AM
Clayton24's Avatar
Clayton24
Clayton24 is offline
Default Recipe for torque
what is hands down the best bolt on for more torque is it bigger bore (cubic inches) ? I have a stage 2 with cams an it helped a bunch im jus not where i wanna b yet on torque /hp mostly torque its a 2015 ultra limited twin cooled with stage 1 plus 57h cams it runs a quite a bit better than stock jus tryin to figure which direction to go next ? Thanks for all replies very apreciated
Old 09-26-2017, 08:53 AM
Yo_Boss's Avatar
Yo_Boss
Yo_Boss is offline
More cubes is always the best way to increase torque.
Old 09-26-2017, 09:13 AM
Clayton24's Avatar
Clayton24
im thinkin maybe what im missing it runs great mid an top just want more torque on the bottom
Old 09-26-2017, 09:57 AM
djl's Avatar
djl
djl is offline
Received 2,232 Likes on 1,614 Posts
Open ended question but more displacement, different cam selection, different exhaust configuration, more compression and headwork all will increase torque. Having said that and specific to your current motor configuration and hunt for more torque, those 57 cams need more than stock compression for optimum performance. You could have the heads worked for better flow and decked to bump compression to about 10.2, retune and you might be happy. If that doesn't float your boat, get the check book out.
Old 09-26-2017, 10:06 AM
IronAss's Avatar
IronAss
IronAss is offline
Received 12,258 Likes on 4,784 Posts
When I put a Thunderheader on my Twinkie it boosted Torque by 12 pound feet and HP by 10.
Old 09-26-2017, 10:50 AM
Clayton24's Avatar
Clayton24
well not verified but the twin cooled advertises like 10:1 or 10.2:1 or sumwhere in that range but my exhaust is stock gutted head pipe with rcx 4.5"slipons ? Im not sure how that adds up for low end torque or if there's a much better option ? All replies appreciated
Old 09-26-2017, 11:08 AM
Clayton24's Avatar
Clayton24
what would be a realy good option for head work ? With a 110 drop in kit i think that may be the key is big bore with head work ?
Old 09-26-2017, 11:16 AM
springers4ever's Avatar
springers4ever
springers4ever is offline
Cool ride anywhere TQ and HP ...
You need to check out this thread ...and combo ....all the tq and hp you'll need for that big heavy bike ...even loaded and 2 up ...!!
ask me how i know !!!
https://www.hdforums.com/forum/engin...-lbs-pics.html
Old 09-26-2017, 11:28 AM
martinj's Avatar
martinj
martinj is online now
Received 17,339 Likes on 6,865 Posts
Twin cooled compression is advertised at a nominal 10:1. Better than 9.6:1 (air cooled CR) to be sure, but in reality most twin cooled engines are probably more like 9.8-9.9:1 actual static compression. Get the compression where it should be at 10.2-10.25:1 and do some head work while you're at it and you'll be well on the way...
Oh, yeah. A good exhaust system is going to help. A lot.
Old 09-26-2017, 02:28 PM
bustert's Avatar
bustert
bustert is offline
Nox & jato
Quick Reply: Recipe for torque
