Oil Pan Hex Bolts
Oil Pan Hex Bolts
Developed a small oil leak on the transmission side of the oil pan. I tightened the hex bolts around the oil pan and noticed a couple of them were loose and one had a stripped head when I went to tighten it.
Does anyone know what size and length these hex bolts are?
Is there a supplier other then Harley?
Any suggestions when installing new bolts?
Thanks!
Thanks!
