Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
As I understand it, most pistons from the factory are in the hole. If the cylinders are then zero decked, would that bump compression up, down, no difference?
Thanks!
If you reduce the area that the cylinder volume is compressed into, you increase compression. So if you make the combustion chamber in the head smaller by milling the head surface, compression increases. If the piston stock, is say 0.050 below the deck of the cylinder and you reduce that by machining the base of the cylinder, lowering it into the case, or mill the top of it ( same effect) and now that 0.050 is only 0.025, you increase the compression.
