Need help with a '97 Electra glide dying after 10 miles
Old 08-16-2017 | 09:29 PM
Dan Albert's Avatar
Dan Albert
3rd Gear
Default Need help with a '97 Electra glide dying after 10 miles
Hi all, hopefully someone can help... I have a 97 Electra glide with 42k. All stock. After I ride for 10-12 miles, it dies out. Won't turn over, unless I remove the plugs. After I pull the plugs and spin it over I can reinstall the plugs and it fires up and keeps going. I don't see any fuel leaks in the tank lines (inside the tank) nor do I have any check engine light or codes. Just before the bike dies, it starts running poorly, as if it's starved of fuel. It seems to be running hot and possibly lean (plugs are white and the pipes glow cherry red off the heads) not sure where to start on this one...
Old 08-16-2017 | 09:57 PM
marcodarq's Avatar
marcodarq
check and see if you have a vacum leak to your petcock, if you have the stock vacum petcock and the line is leaking, the valve will not operate correctly and this symptom can happen. check for other vacum leaks as well while you are at it.
m
Old 08-16-2017 | 10:13 PM
Baird's Avatar
Baird
Not very familiar with the vacuum operated petcock, but that sure sounds like leaning out and fuel starved. How is the tank vented to atmosphere? Next time it starts to die, loosen the gas cap. if it runs normal you found the problem.
Old 08-16-2017 | 10:20 PM
Dan Albert's Avatar
Dan Albert
3rd Gear
I did run it with the cap loose... for about 10 miles. Then it died. I'll look into the petcock and vac leaks, but loosening the gas cap has no affect. Thank you for your insight!
Old 08-17-2017 | 06:10 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
If the headpipe is red, the exhaust valves are very hot also.
If not the petcock, the ignition could be the culprit.
Scott
Old 08-21-2017 | 04:20 PM
Dan Albert's Avatar
Dan Albert
3rd Gear
Investigated a little further, no problems with the petcock or vacuum lines. The ignition wiring appears to be fine, ignition works as it should and I don't see any evidence of an issue. This thing is killing me... Anyone have any ideas on what else I could look for?
Old 08-21-2017 | 04:34 PM
81rat's Avatar
81rat
What you are describing is typical of the Elect. Ign. unit gone bad ( carb engine )
Engine start just great -- warms up can't keep it running low RPM shuts off --- Engine cools off appox 1/2hr -- engine starts just fine till the heat returns then shuts off .
Over and over again till you change the Ing module
ebay --$125 -- Ultima #53644 --fits in the Cam nose cone -- all factory stuff goes to trash ( Recheck the part # )
Old 08-21-2017 | 04:36 PM
marcodarq's Avatar
marcodarq
Your bike is av Evo, correct? I think the next thing to look for is if younare loosing spark once it gets warmed up,,,,,the timer pick up plate in the nose cone of the cam cover falis and has this symptom,,,,,the time it takes for you to pull the plugs and spin it might give it enough time to cool off and work again....
Get the bike warmed up till it quits, then immediately check and see ifnyou have spark or it went away....if it went away, you know its ignition,,,,,,the take the timer covre off, get it hot till it quits, then try to quick cool the sensor,,,safest way is probably blowing on it with compressed air,,,then try it and see if it tuns again...if so or if the sensor looks melted down, replace it set timing, best to mark it prioir to removal, then have fun!
M
Old 08-21-2017 | 04:44 PM
81rat's Avatar
81rat
As marcodarq said about marking
With the Ultima --mark the 'V' notch for adjusting very good and replace exactly where the old notch was -- will fire right up and run , but still need to double check timing
Old 08-21-2017 | 05:06 PM
Dan Albert's Avatar
Dan Albert
3rd Gear
Yes, it's an EVO EFI. I'm 99% sure I replaced the ignition module last season. Doesn't exclude it, but I only managed a couple hundred miles last season and less this year. I'll do some more looking tomorrow. Thanks again for the help, I'll take all I can get!
