How to use roller style cams on 03 night train
I was wondering how would I be able to use newer style roller chain drive cams in my 03 Night Train? I bought the S&S TC3 cam plate & oil pump which is 07-up style with the hydraulic tensioners and want to use 07-up style roller cams instead of the older " silent " style. Can anyone please tell me if I can switch to the newer style and what else I would need to do in order to do so? I would really appreciate any feedback! Thanks in advance!
Well, you must replace the cams since the link sprocket is part of the inner one. And truly, this is the only true upgrade other than gears. Would think it hardly matters on a 03, however, when the spring tensioners are $150 and last 50K, but whatever you like.
Before you buy, make sure to match all. Not sure if there is still a kit. Best I can tell it is no longer available. Someone said it was aftermarket but I read Harley quit selling to the aftermarket their parts to match with aftermarket cams.
Search Andrews and S&S
I've seen the spring tensioners break apart at 2k miles and seen bike with 15k and barely any ware, so there's no telling and with all the money I'm putting in my bike, I'd just rather use newer style with better oil pump. I know Andrews sells conversion kits with their " N " style conversion cams, but I'm going with S&S 583s and want to use the 07-up style instead of the " silent " style as I've heard how they're not as durable and can also stretch causing timing issues especially with higher compression engines. I know the TC3 cam plate is new style, but thinking that maybe the bearing journal in case is smaller or something than 07-up style.
How would I do that? I just purchased S&S 98" bore kit, as I mentioned above I have the hydraulic tensioner set-up and going with Easy Start 583s but wanna use roller style. Curious as to how I would modify them? Thanks
As mentioned by others you MUST use a special build cam set. Many of us have them and I would think that S&S has them as well. Your going to have to give them a call to find out for sure. The special part of it means its a '07 and up cam set with the inner cam bearing surface reduced to the'06 and earlier style. You also need the inner and outer chains, gears and tensioners too.
I spoke with them and the guy i was chatting with said that they don't have those style cams, which is disappointing cause you would think they would carry them if Andrews, Feuling etc carry them. I already have their TC3 plate, pump & tensioners and I really wanted to go with the 583s. Is there a replacement " silent " style chain I can purchase that is more durable and will hold up better than the stock? If not, looks like my only other alternative would be to go with gear drive.
