FXSB - HIGH RPM and NO START. HELP!!!!
My 2014 FXSB Breakout is having an intermittent idle issue. On occaison the RPM will run high and get stuck between 2000-2500. This occurs while riding and it takes a while to come back down, if it even does. When this happens, after you shut it off, it will not start again until the motor cools down. The IAC has been replaced already, but did not correct the problem. Has anyone had anything similar to this? No diagnostic codes are given and since its intermittent, the shop has no idea whats causing it. I don't want to start replacing sensors just to replace them. I pulled out the power commander and the issue persisted and it would not start. After sitting for about 2 hours it now starts and is running normally. Any insight would be appreciated.
The throttle snaps right back, fully released and no hang ups. When the RPM gets stuck its like having cruise control. After that, you have to hold the throttle to start it again or will just crank, start rough for a second, and then stall. That is unless you let it cool off, then may run normal, rpm get stuck, or stall once you let off throttle while riding. I have no ideas and the shop guys say it can be a lot of things but going to be hard to find.
Lambda
24
05-22-2021 09:18 AM
Z_Stingray
05-27-2008 07:34 PM
