Pushrods - standard or adjustable?
Old 05-09-2017 | 02:30 AM
Road Star's Avatar
Road Star
Veteran: Marine Corp
Default Pushrods - standard or adjustable?
Wondering what's better? Seems like there's less room for error when using standard solid pushrods.
Old 05-09-2017 | 05:52 AM
nhrider1's Avatar
nhrider1
Less room for error yes, but with adjustable push rods you can set and adjust the amount of preload on the lifters (quieting some noisy lifters).
I always use adjustables when changing cams. Adjustment is straight forward, less engine disassembly, and I've never had a problem with them. They also make any lifter replacement down the road easier. So there are a number of positives.
Old 05-09-2017 | 05:58 AM
Stiggy's Avatar
Stiggy
With mild cams I prefer the stockers. Less parts to worry about. I had a locknut loosen on my adjustables and fortunately was almost home so I limped it. It sounded like a bucket of bolts by the time I shut it down, running on one cylinder.
Old 05-09-2017 | 07:09 AM
Road Star's Avatar
Road Star
Well, I do have adjustable ones now, just wondering since I have the top end open. Also, been running Andrews 37G cams.
Old 05-09-2017 | 10:00 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Standards are the safe way but I like adjustables. As noted they have other benefits and the chance of a retaining nut loosening up is not as common as you would think...
Old 05-12-2017 | 12:27 PM
hog-doc's Avatar
hog-doc
Especially not when they are tightened properly!
nutoy
Engine Mechanical Topics
10-06-2014 07:24 PM
rkduq20
06-07-2013 08:00 PM
jrgreene1968
03-29-2013 01:31 PM
1fathog
12-13-2011 12:16 PM
lionsm13
12-27-2009 11:50 AM
