Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I have a 2010 streetglide and the front cylinder is started making a strange noise at idle. Has anyone ever heard a motor sound like this? any ideas?? thanks for the help
Do you have upgraded cams in your bike?
Sounds like reversion.. but on mine it's a single " wooden drum" sound.
I hear a double tap noise in your vid.
Have you checked all your heat shields and what not for loose bolts?
No it's not hitting the frame it's more like a air type of noise strange. I had a new top end put on it 3000 miles ago I hope it's not a top end again.
I just changed the pipes so I did think about that and did crank them down but I may put new exhaust gaskets on there. I changed them out when i put the new pipes but Im going to start over again. thanks
I would take it to a local Indy and let them hear it at the least. I know that when I lap valves into their seats it sounds very similar. That cluck sounds similar to reversion that you get with some cams... Woods cams are noted for that.... Take the a/c off and see if it gets louder.....
