Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I'm about to upgrade my 04 carbureted engine to a S&S 100
i wanna upgrade my carburetor . any suggestions. ?
i know i can just replace the jets on the stock one .
but since i spend that much for set up might as well go all out . thanks
If you haven't bought your kit yet you can read the instructions it comes with on the S&S website. They recommend using an E or G carb, not surprisingly. An alternative is a Mikuni.
