Darkhorse/S&S/WFO Larry 117" build time.
Old 04-19-2017 | 12:34 PM
Reindeer's Avatar
Reindeer
Originally Posted by cvaria
how do you check the run out at home.
I was thinking i could have the dealer do it but, at that point. The chest is open and the labor is 1/2 done. Why not just in stall the cams/gear if with spec..and chain cams if not... that would require having both types of the chosen grind on hand at thhe time of testing to avoid basically paying for the cam install twice. By having it tested then getting a set of either then going back in for an install.
does that make sense or am i under thinking this?
Run a dial indicator on the crank snout at the point where it passes through the camplate. I bought a setup off Amazon, not terribly expensive.
  #32
Old 04-19-2017 | 01:34 PM
djl's Avatar
djl
Check runout and order chain or gear drive cams based on results. Check with dial indicator or a home made fixture; see the attachments. Or, the Fueling tool available from Amazon.
Amazon Amazon
Attached Thumbnails Darkhorse/S&S/WFO Larry 117" build time.-runoutchecksetup.jpg   Darkhorse/S&S/WFO Larry 117" build time.-crank-runout-checker.2.jpg
  #33
Old 04-19-2017 | 02:02 PM
cvaria's Avatar
cvaria
https://www.amazon.com/Feuling-Indic...7GB15R8X9V82HN
thanks, ordered
  #34
Old 04-19-2017 | 02:54 PM
multihdrdr's Avatar
multihdrdr
thanks, ordered
C, that's only for the dial indicator #9016...not for the holder too
$25 is the first give away
  #35
Old 04-19-2017 | 03:24 PM
cvaria's Avatar
cvaria
well that solves the mystery of the 25 vs 110 price.
corrected... ordered. I still don't know what I'm doing
  #36
Old 04-19-2017 | 03:34 PM
djl's Avatar
djl
I just posted the picture as an example of another fixture and way to measure; not a replacement for due diligence. I just grabbed the first one that popped up and assumed cvaria could take it from there and order what he needed.
  #37
Old 04-19-2017 | 03:44 PM
cvaria's Avatar
cvaria
I just posted the picture as an example of another fixture and way to measure; not a replacement for due diligence. I just grabbed the first one that popped up and assumed cvaria could take it from there and order what he needed.:icon_doh
yeah, maybe dont do that grab and post thing. Thanks anyway. I corrected the order. All good, you were trying to help
  #38
Old 04-19-2017 | 03:45 PM
soft 02's Avatar
soft 02
Cool! You're going to love the power!
  #39
Old 04-19-2017 | 04:02 PM
djl's Avatar
djl
I could but I won't. It's Amazon, easy fix and glad you figured it out; I'd be worried about you if you hadn't. It wasn't a "trick" post.
  #40
Old 04-19-2017 | 07:25 PM
Reindeer's Avatar
Reindeer
That's the idea.
Quick Reply: Darkhorse/S&S/WFO Larry 117" build time.
