Darkhorse/S&S/WFO Larry 117" build time.
Old 06-07-2017 | 11:44 AM
Reindeer's Avatar
Reindeer
I used the seals and flanges that came with the SE manifold. Everything fit together nicely, but it seemed to me like the seals should have been thicker for a tighter seal. Looking at it now, it's quite obvious that I have it installed wrong.
This picture was taken when I first suspected and then confirmed an intake vacuum leak. I took it apart, added a light bead of high temp RTV, and reinstalled it, being careful to make sure the seal lined up. Of course, that's all irrelevant if it's assembled incorrectly in the first place.
I suppose that's one of the dangers of taking something apart and putting it back together several months later.
Attached Thumbnails Darkhorse/S&S/WFO Larry 117" build time.-photo826.jpg
The following 2 users liked this post by Reindeer:
Max Headflow (06-07-2017), mirrmu (06-08-2017)
  #142
Old 06-07-2017 | 12:13 PM
Max Headflow's Avatar
Max Headflow
Well, I guess that's one way I hadn't thought of..
  #143
Old 06-07-2017 | 12:30 PM
Reindeer's Avatar
Reindeer
Yep.
  #144
Old 06-09-2017 | 06:26 PM
94 ultra's Avatar
94 ultra
anything new?
  #145
Old 06-09-2017 | 09:29 PM
RKGDCG03's Avatar
RKGDCG03
Veteran: Coast Guard
Are you sure that the ends of the manifold are not resting on the heads? When I decked my heads I had remove material from the manifold to let the manifold go down further to line up so the seals were centered.
  #146
Old 06-09-2017 | 10:11 PM
Max Headflow
Look at the picture in message 141 and you'll see what the issue is..
  #147
Old 06-10-2017 | 10:59 AM
Reindeer's Avatar
Reindeer
I talked to the shop yesterday, they correctly installed the manifold flanges for me and confirmed that solved the idle issue.
Should be on the dyno early next week.
The following 4 users liked this post by Reindeer:
AllenW (06-12-2017), cvaria (06-10-2017), Max Headflow (06-10-2017), mirrmu (06-10-2017)
  #148
Old 06-10-2017 | 04:14 PM
Fat11Lo's Avatar
Fat11Lo
That's good to hear, interested to see your results
I got my parts last Friday, plan on spending some time out in the garage this weekend.
  #149
Old 06-14-2017 | 11:40 AM
Reindeer's Avatar
Reindeer
Bike is done. Anticipate a full report tonight.
cvaria (06-14-2017)
  #150
Old 06-14-2017 | 05:28 PM
cvaria's Avatar
cvaria
Thumbs up
good news for somebody today... i'm pissed. lol
Quick Reply: Darkhorse/S&S/WFO Larry 117" build time.
