Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Will these Heads work on an 01 TC88? Screamin' EagleŽ Pro Kompressor Cylinder Heads - 17044-08A
Yes but know that those heads have been decked to produce 10.5 static CR with OEM pistons, so, if running aftermarket cams with earlier intake close events, you need to watch CCP. You will also need '06 up intake flanges, PN 26993-06. The springs in these heads will accommodate up to .585" lift by the book but might work up to .600" if checked for coil bind first.
I have to ask, for $500, why not have your heads ported? The end result will be better.
Actually they are probably about only 9.5 to 1 with stock 88 ci pistons.. According to the 2010 catalog the need high compression pistons to get 10.5 out of an 88.. On a 95 motor they only squeak out 10 to 1 with flattops.. They do get 10.5 out of a 103 tho..
They are pretty much stock later heads that have been milled a bunch and heavier springs added. Better options out there for sure.
Actually they are probably about only 9.5 to 1 with stock 88 ci pistons.. According to the 2010 catalog the need high compression pistons to get 10.5 out of an 88.. On a 95 motor they only squeak out 10 to 1 with flattops.. They do get 10.5 out of a 103 tho.. They are pretty much stock later heads that have been milled a bunch and heavier springs added. Better options out there for sure.
Right, failed to mention that compression will vary with bore diameter.
Would it be worth the cost to purchase a set of 07 heads and have them ported & polished for my stock
2001 EG . I enjoy my fuel mileage Just not ready to start messing with this MM injection system yet
thanks in advance for helpful information
