Head swap?
Head swap?
I'm thinking of adding new heads to my build. Can I just swap heads out or do I need to remove the cylinder and replace the gasket at the bottom of the cylinder. I have heard once you Un torque your heads and cylinder you should replace that bottom gasket to prevent potential leaks down the road. We just did a 110 kit 1600 miles ago so I Know that gasket is good, but at that time I keep the heads stock now I want to add heads.
Think it through, stay calm, don't hurry and keep the manual handy for question or that 3rd look see to make sure and you'll get through it. These things are fairly forgiving or half the guys doing it wouldn't be out there in shops right now.
Just don't get frazzled that's when mistakes get made.
Not really a must but handy. One thing to remember when taking on work that may not be necessary; the deeper you go, the more opportunity for mishap. Some mishaps are easy to over come and some, like dropping a pin retainer into the crankcase are not; my grandma used to call something like that "borrowing trouble". You really shouldn't have to remove cylnders and pistons and replace the base o-ring. The heads will very likely lift right off, secure the cylinder with the 1/2" PVC couplings and move on to the next one.
However, if you must replace the base o-ring, you can remove the cylinder/piston as assembly and leave the piston in the cylinder. Another operation that requires attention to detail and taking your time. Do one at a time and slide the cylinder up just enough to expose the piston pin; remove the pin and pull the cylinder/piston assembly as a unit without disturbing the rings. Make sure you have some shop rags (I use those big car wash sponges cut to fit) to stuff into the case to prevent dropping anything into the crank case; that will ruin your day.
Like I said in my first post, extra work that is not necessary if you proceed with caution.
msocko3 (03-06-2017)
