What would you do
Old 03-03-2017, 10:25 AM
Rfc's Avatar
Rfc
Rfc is offline
Default What would you do
2013 RG Custom bought new. Had some noise coming from the primary so I had my INDY open it up. Diagnosed with 7-8 fractured crank side splines. Bike has 16,000 miles on it. Here's the estimate...
Old 03-03-2017, 10:57 AM
djl's Avatar
djl
djl is offline
Received 2,223 Likes on 1,608 Posts
If funds are available, take advantage of the situation and have machine work done for 4.125" cylinders and go big! If less funds available, maybe a 110" drop on kit. If no funds available, let the indy fix.
Old 03-03-2017, 01:38 PM
Tedwilliams09's Avatar
Tedwilliams09
Tedwilliams09 is offline
I agree with DJL.. If you can swing it why not make it bigger now?
Old 03-03-2017, 02:42 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,974 Likes on 4,044 Posts
It looks good but I would add a new compensator, it is likely shot and the reason for your crank going bad. One thing to note is that he has 2 prices for main bearings, IIRC the lefty SE bearing is the same for both sides.
Also add in inner cam bearings (SE) and tensioners if they look bad. Tensioners should be OK..
Old 03-04-2017, 07:09 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
ide go 124",ide also add a Timken insert.but if you are just going to stay the same CID,just find another OEM 4.375" crank & have it rebuilt.alot cheaper than a S&S F/W ***`y
Old 03-04-2017, 07:55 AM
TXCHOP's Avatar
TXCHOP
TXCHOP is offline
Out of curiousity, did the tech send you pictures of the damage?
Old 03-04-2017, 08:03 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
The load that is required to harm that is tremendous, and one would suspect that if in fact, if it occurred, and hanging on by a fingernail, why would the remainder not be peeled away?
Scott
Old 03-04-2017, 09:09 AM
Gordon61's Avatar
Gordon61
Gordon61 is offline
I obviously don't know what happened but at 16K miles on the clock I would be shouting at HD with terms like fit for purpose
Old 03-04-2017, 09:50 AM
squirrelsnest's Avatar
squirrelsnest
squirrelsnest is offline
Received 5,659 Likes on 2,811 Posts
Wow...those number add up....fast!
Old 03-04-2017, 10:03 AM
Rfc's Avatar
Rfc
Rfc is offline
Even if out of warranty?
Quick Reply: What would you do
