Is the cam support plate a wear item
Old 12-29-2016, 03:43 AM
65Tiger's Avatar
65Tiger
65Tiger is offline
Default Is the cam support plate a wear item
08 Road King with 85,000 miles
I am getting ready to open up the cam chest for a Woods 777 cam change as part of a motor rebuild and want to have all the parts in hand
I see that the new style cam plate has the cams running directly in the aluminium plate (not even a bushing), rather than a bearing like my 00 Dyna. I do see a bushing for the crank end
I see that there is no shortage of aftermarket cam plates so either a "better" one is desirable or it is a wear item?
Should this be considered a wear item, and if so does it have a life?
Old 12-29-2016, 11:39 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,866 Likes on 2,429 Posts
I suspect your bike has that same camplate and it has already done 85k miles! Probably fine for a great many more. It is only 80 bucks to replace, if you have any doubts about it. The plate of course is not made only of aluminium, but an alloy including several other metals, which make it perfectly suited to it's job. That design is increasingly common throughout the motor industry, so is not peculiar to H-D.
Old 12-29-2016, 01:48 PM
boston jim's Avatar
boston jim
boston jim is offline
Contact IB Sales to have your account opened
I'd ask Woods, what they recommend for a Cam Plate, they Must have a Preference?
Old 12-29-2016, 06:01 PM
todd-67's Avatar
todd-67
todd-67 is offline
Received 3,407 Likes on 1,593 Posts
They didn't start runing directly on the plate until 2010?
Old 12-29-2016, 06:11 PM
Kingofcubes's Avatar
Kingofcubes
Kingofcubes is offline
I install a new bushing if needed.
Old 12-29-2016, 07:01 PM
djl's Avatar
djl
djl is online now
Received 2,223 Likes on 1,608 Posts
'07 and on. I would consider it a wear item.
Another brilliant bean counter vice engineering coup from the MoCo considering that the earlier cam plates ran the cams in bearings; why change? Just think how many bearings the MoCo no longer has to buy. No worries though, if you are concerned the MoCo will sell you a pretty orange billet plate with bronze bushings for the cams to run in and a higher capacity oil pump for about $400.
Old 12-29-2016, 07:02 PM
djl's Avatar
djl
djl is online now
Originally Posted by 65Tiger
08 Road King with 85,000 miles. I am getting ready to open up the cam chest for a Woods 777 cam change as part of a motor rebuild and want to have all the parts in hand. I see that the new style cam plate has the cams running directly in the aluminium plate (not even a bushing), rather than a bearing like my 00 Dyna. I do see a bushing for the crank end. I see that there is no shortage of aftermarket cam plates so either a "better" one is desirable or it is a wear item? Should this be considered a wear item, and if so does it have a life?
I would consider it a wear item; see #6.
Old 12-30-2016, 09:36 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,974 Likes on 4,044 Posts
The specs for the pinion and cam bearings are in the SM.. Replace if over those.. Your could replace the bronze bushing if out of spec but I'd bet the outer cam bearings are likely close to worn with that many miles..
Old 12-30-2016, 09:48 PM
65Tiger's Avatar
65Tiger
65Tiger is offline
Given no bearing or bush at the cam ends, that is what I suspect and why I asked before opening it up.
I found a NOS one for 45.00 USD so by the time I bought the bushing at the crank end it was a no brainer.
Old 12-31-2016, 04:02 PM
Sc0-'s Avatar
Sc0-
Sc0- is offline
Most other engines have cams that ride in the parent materials, no problems until something catastrophic happens. I would prefer bearings or some sort of bushing to feel better but it works fine.
Quick Reply: Is the cam support plate a wear item
