Is the cam support plate a wear item
Old 12-31-2016, 05:07 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,976 Likes on 4,045 Posts
Originally Posted by 65Tiger
Given no bearing or bush at the cam ends, that is what I suspect and why I asked before opening it up.
I found a NOS one for 45.00 USD so by the time I bought the bushing at the crank end it was a no brainer.
Sounds like you are headed in the right direction.. The only thing is that I'd check the bearings and if they are OK use the original plate. I've read complaints about some being worn out when torn down but really don't have any direct experience.
Sandcrab
10-01-2020 11:32 AM
BulldogBiker
Exhaust System Topics
06-30-2012 08:48 PM
roger scarcliff
12-06-2010 08:34 PM
32roadking
09-19-2008 01:39 AM
dawg
10-10-2006 06:33 PM
Quick Reply: Is the cam support plate a wear item
