DIY Throttle body honing?
your not going to do much.porting a t. body has more to do with the runners,not the t.body itself.i made a fixture to bore the OEM runners,but 1.720 is about as big as you can go without getting it too thin.boring & porting a OEM t.body will pick it up a bit,but your really better off getting a HPI unit with bigger runners (depending on what your trying to do) I made a fixture to make my own throttle plates,but really don't bother too much anymore,its easier & more cost effective just buying one
Porting the t/body manifold will help, but you are not going to accomplish much with that method.
We bore the 2 pc Delphi to 46.5mm,(throttle plate goes from 1.630", to 1.840") and the single piece to 50mm.
We manufacture our our throttle plates.
They both work well, and are a cost savings over/above a complete new t/body.
Scott
Scott
sure,we saw improvments with our bored t. bodies,good improvments.but for the $$ spent,its better (IMO) to spend a couple bucks more & get a bigger t. body with bigger runners.a bored OEM t. body works OK on a up to 95" build,anything bigger (with decent heads anyway) needs a bigger throat/runner t. body to not leave hp/tq on the table
HDSAE60 (11-30-2016)
fuelmoto
Milwaukee Eight (M8)
33
06-19-2020 01:35 PM
