disabling factory set speed limiter
I wanted to baseline dyno my present 2014 103HO engine combo before proceeding with some upgrades this winter. It is my understanding that international models that the ecu is set for a 110mph limit. This showed upd showed up on the dyno runs as the engine shutdown at 110 mph in fifth gear at 4300 rpm.
Is it as simple as unplugging the VSS on the transmission (will that set a code) or does the limit need to be changed in the ecu?
Thanks
Jerry
Thanks
Jerry
