Swapping 103" tope end to my Wide Glide
Ok, so my 110" bolt on kit for my 2014 SGS arrives Wednesday. I want to put the top end on to my 2010 Wide Glide. The top end currently has 10k miles on it and going onto the 5200 mile WG.
Other than new gaskets, should I replace anything like the rings? I know my 103" has ACR's but dont think the WG has them. Any advice?
Some will say not to bother changing rings with that kind of mileage but I would while it's all apart. As for no acrs, no big deal unless you're changing to cams that would require it. If that's the case use the s&s ezy start cams and then no need for compression releases
rough rider
08-31-2010 12:12 AM
Mxjunkie
11-08-2005 10:11 PM
