What xould be causing this leak?
Old 10-11-2016 | 04:14 PM
mclldavidson's Avatar
mclldavidson
Default What would be causing this leak?
03 Fatboy
Old 10-11-2016 | 04:18 PM
soft 02's Avatar
soft 02
Lower rocker box gasket.
Old 10-11-2016 | 06:29 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Duh-yup!
Old 10-14-2016 | 07:46 AM
BezerkoBob's Avatar
BezerkoBob
Originally Posted by mclldavidson
03 Fatboy
Have you had the rockers off? Like to install Rocker Lockers or for any other reason? Could be that the bottom of one of the blind holes that the rocker lever bolts go into broke off. This can happen if the oil is not removed from these holes before you install and torque the rocker bolts. The material is not very thick right there. They will hydraulically pop off the bottom of the hole. Then you will have a slow but steady oil leak from the bottom of that bolt hole.
Old 10-20-2016 | 08:29 AM
BezerkoBob's Avatar
BezerkoBob
So have you found the source of the leak yet?
WS6 Formula
07-05-2018 12:33 PM
husky390
EVO
07-29-2017 08:05 AM
DEG147
09-03-2016 09:42 AM
deanp1964
Exhaust System Topics
12-12-2011 07:44 PM
popstheoldman
Ironhead
18
03-15-2010 05:51 PM
Quick Reply: What xould be causing this leak?
