Please help!!!!!
Old 09-18-2016 | 05:33 PM
ChopperGuf's Avatar
ChopperGuf
4th Gear
Default Please help!!!!!
Just put in the S&S 107 kit with 585 cams adjustable pushrods rocker arms lifters fueling HP oil pump and cam plate. Having over heating problems not getting all the power when I turn the throttle and finding flakes in my oil please help.
Old 09-18-2016 | 05:49 PM
booyajj's Avatar
booyajj
have you check to see if your cam are rubbing
Old 09-18-2016 | 06:22 PM
ChopperGuf's Avatar
ChopperGuf
4th Gear
neg I will try that thanks.
Old 09-19-2016 | 02:55 PM
baloot-boy's Avatar
baloot-boy
When you say overheating problems, can you be more specific? Temps? Symptoms? Did you already break in the pistons and rings? What tuner are you using? Has it been professionally tuned?
Old 09-19-2016 | 04:25 PM
Mike Lawless's Avatar
Mike Lawless
I would say finding flakes in the oil is the major concern. That's a pretty good sign that someting's FUBAR'd
Old 09-19-2016 | 04:35 PM
soft 02's Avatar
soft 02
Doesnt sound good!
Old 09-19-2016 | 04:38 PM
djl's Avatar
djl
Flakes could come from a variety of sources. Go online and get a sample collection kit from Blackstone and have the oil analyzed.
Poor power and over heating are classic symptoms of sumping which is the result of poor seal between the oil pump and scavenge port or oil pump not aligned or both. Easy to check by removing the case plug on the bottom of the right side case under the crank case. Carefully remove the plug and see how much oil comes out. If more than 4-6 ounces, the motor is sumping. Carefully re-install the plug with some Loctite thread sealant and do not over tighten; the plug is tapered and if you go "gorilla" on it, you can crack the case.
If she is sumping, a "do over" of the work you just completed with particular attention to the o-ring at the scavenge port and the seating of the pump neck in the scavenge port as well as following the proper procedure for aligning the oil pump will solve the sumping issue.
The flakes in the oil could be from initial contact of new parts. The oil analysis will tell you whether or not you should be concerned but I would be addressing the loss of power and overheating issue first.
BTW, I have never been impresses with the Fueling pump and plate; the OEM parts do a better job IMHO..... Check out FlatHeatWave's post "Fueling Oil Pump/Cam Plate" in this section.
Old 09-20-2016 | 05:30 PM
Max Headflow's Avatar
Max Headflow
So if you're seeing flakes in the oil, what is sending the oil off to be analyzed gonna do? Tell you everything is OK?
Old 09-20-2016 | 05:37 PM
Max Headflow
If you used roller rockers, you were lucky it even started. Rocker cover needs clearance. Bike needs tune. Flakes mean you need to pull the cam case, oil pan and clean out the swarf. Late model TC will clear a 585. Early 5 speeds probably won't.
Old 09-20-2016 | 06:07 PM
soft 02's Avatar
soft 02
No but it will tell you if its brass, aluminum, copper or steel. That will help you know where to look.
