96" to 103" swap questions
I know, I know this is a wicked old thread, but my question applies specifically to this issue so bare with me. When you did the swap how did you approach the differences in the motor mounts? I am swapping a 103 motor and trans from a 2014 into a 2006 Street Glide frame. The TCA motor is rubber mount. The frame for the 06 is not. Anything else that I will run into that you can think of off the top of your head? Appreciate your time.
Yes. In fact you should be able to go back to the stock top mount if you don't want to add the link to the front of the frame. You'll also need to check the clearance between the left floorboard mount and the primary case but going into an 06, I suspect there is plenty.
And another... replying bring an old post to life again. @Notgrownup I’ve been searching ( and maybe I’m using the wrong words)... but I’m looking for details on swapping a new 103/110 (from a 2011/2012 ) into my 07 king. Understanding I have the small rear wheel... what’s needed as far as the frame with the newer motor having the 4 motor mount points vs the 3 point frame on the 07 models .
Thanks for any help.
