Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
............especially the ones prior designed/manufactured/marketed by others.
Not an S&S hater at all, quite the contrary, as we do a large volume with them, but have witnessed things that certainly make one raise their eyebrow.
Scott
I think these would be great if building from scratch and gears weren't used. I think the same about their 3 stage pump. I don't see everything in the aftermarket as just a replacement.
Fixing a part that isnt broke! That said I put the Zippers tensioners in my chest. If I was installing their pump/plate id probably go with their tensioners as well.
Scott
Same here.. Not dissing the parts.. One has to question where it's needed tho.. 0.675 lift cam with chains.. Probably worth a try.
