Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
How do you determine which pinion gear to get? Got a new S&S Evo crank, new cam...do i order the standard red gear or is there a specific way to figure this out.
You can measure the cam gear and pinion gear and match them. You need to use the correct gauge pins for the measurement.
S&S outlines the procedure and the matching parts in their cam instructions.
I've attached a link to the instructions:
