95 cu in Upgrade Questions
I have an 2003 Ultra Classic I purchased last summer with 78,000 miles on it, I just hit 90,000 last week and am thinking about a top end rebuild this winter. This got me to thinking though that while I have it apart I may as well do some upgrades, meaning going from stock 88cu in?to a 95 cu in.
This brings me to my questions
What other than cylinders, pistons, cams do I need?
What does the process of "porting" my heads involve, or should I replace those as well?
Being fuel injected what issues and costs roughly will I be looking at to get it tuned again once the work is done?
Apologies if these seem like simple things to answer but other than basic maintenance I've never done something like this and plan to do all the wrenching myself. If I think of anything else I'll add it
Definitely intend to replace the valves while I'm in there, much easier to do all that while it's torn apart than to have to go back later and do it. Especially considering I have little to no history on the bike prior to buying it.
Looked at the S&S 95cu in hotsetup on Jpcycle.com today, comes complete with cams, heads, pistons, gaskets,etc. Curious about the gear driven cams though (doesn't come with a chain driven option) as to if it is worth it after spending $3,000 on the kit and potentially having to spend another $1,000 to true the crank should it be out of tolerance.
Does anyone have other suggestions for kits or a list of suggested parts to piece together into a kit of my own? And would the cost of having my heads ported (rather than going with the heads in the kit on jp) myself at a local shop end up cheaper in the long run?
Here is the link to the kit.
http://www.jpcycles.com/product/420-276
First thing you should do is write down your riding style. (Long trips, bar hopping, drag racing, all of the above, etc.)
Second thing is how long do you plan on keeping the motorcycle? Couple of years, not worth putting money into but last Harley you plan on owning, sky is the limit.
And intend to keep the bike for awhile hence why I'm wanting to do the work in the first place.
more power
Matt,
making good power is not all that difficult. Simple way of putting it is the heads make the power and it is the cam that dictates where in the rpm range the power will be. As mentioned before you need to think about where you want most of your power, top, middle, or bottom end. doesn't make sense to build a motor to have power in an area that you do not drive. I would suggest you work with some one that has experience in doing this type of work and that you are comfortable with their ideas on how to achieve what you want. you'll need to talk to the porter and the motor builder to get all the info you need for this project. do not be afraid to ask questions. a dumb question is often cheaper than a dumb mistake. good luck dsv
That has been a thought which is why I'm trying to figure out what it'll cost to have the work done vs. A whole new engine. Either way it may end up being to costly for me right now. Starting to thinkick about just a stock rebuild with a new set of cams.
