Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Under the engine I have a small drip of oil showing up on the clutch cable. I wipe it down, the next day its there again. I put a new anti rattle clip on the lever and squirted cable lube inside the cable while apart. I also recently changed my Transmission fluid. Can't find the source of the drip?
What did you use to lube the cable? Could be over lubed and excess is just dripping out. Or it could be that the o-ring that seals the cable in the trans cover is not sealing. Probably not oil dripping but tranny fluid.
Has your cable rubbed on the underside of the cam cover area?
Before wiping it off again, get s torch & check to see if you can follow the oil trail to where it starts.
How much oil did you put in the transmission?
That’s where I found my leak at the cable rubbed against an formed a good size hole
