stock 5th gear slipping - whats a good 6 speed clutch upgrade besides stock - recommendations?
Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
5th gear is slipping with clutch fully engaged and now 6th gear is starting to go, I would like to replace entire clutch on my 2011 FLHR - 6 speed Road King Classic, I just did a WOODS 555 cam upgrade and would like to go with a non-stock high performance 6 spd clutch.
what would any of you high performance gurus recommend? ...thx, Buck
AIM VPC or Bandit Sportsman. Just have to figure out clutch/spring combination for lightest lever pull with clamping capacity required to hold the motor.
No need for a high dollar clutch upgrade. Assuming your current plates aren't burned up from the slipping, all you need is the SE spring or equivalent.
SE spring fixed mine from doing the exact same thing as yours before I did Andrews 57s and D&D Fat Cat. I can hammer it in 5th or 6th now and no slipping.
