stock 5th gear slipping - whats a good 6 speed clutch upgrade besides stock - recommendations?
That is what I did when putting cams in and it is holding just fine. The increase in lever pressure is minimal.
5th gear is slipping with clutch fully engaged and now 6th gear is starting to go, I would like to replace entire clutch on my 2011 FLHR - 6 speed Road King Classic, I just did a WOODS 555 cam upgrade and would like to go with a non-stock high performance 6 spd clutch.
what would any of you high performance gurus recommend? ...thx, Buck
Also be sure that your aftermarket Cable has the same throw as the OE Cable, A bud of mine (tons of miles since the PanHead days) had a Harley Dealer change the bars on his then new '13 Limited with the 555s, Pipe & Tuner, and had nightmares with the clutch until 2 years later, an Indy pointed out that Harley has Cables with different throws, even on the same bike / model... After the proper (throw) cable was installed no more clutch issues...
So many just throw in a SE spring and that will hold but the pull can be a bit much for some. The AIM 340lb spring will hold quite a bit and as you stated the increase in lever pull is barely noticeable.
Captain Itch
09-29-2014 08:28 AM
