Engine performance
Old 06-04-2016 | 04:32 PM
Luis Gomez's Avatar
Luis Gomez
1st Gear
Default Engine performance
my softail has 100.000 miles now, when the engine goes to 2000-2300 rpm it tries to miss like were still cold and when I try to go faster than 70 mph I open up the accelerator full open but do not increase the speed. Any suggestion as to the cause, please.
Old 06-04-2016 | 05:16 PM
Tommy C's Avatar
Tommy C
If it has a CV carburetor check the vacuum piston diaphragm for a tear or hole in it.
Old 06-05-2016 | 09:20 AM
dsvracer's Avatar
dsvracer
Default leak down test
I would start off by doing a leak down test. this will tell you how the health of the motor is. if the valves are leaking a bit then it will show with this test.
sounds like you might need a little valve work. dsv
Old 06-05-2016 | 06:26 PM
98hotrodfatboy's Avatar
98hotrodfatboy
What year and carbed or fuel injected?
I'm thinking it's fuel related, especially if it's carbed....
Old 06-05-2016 | 06:49 PM
checkers's Avatar
checkers
Could clutch be slipping?
Old 06-06-2016 | 06:11 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
When an engine becomes tired, or weak, the signal to the carb becomes less, losing it's ability to wick fuel up thru the jets, requiring a larger jet orifice size.
Perform a leakdown test, and compression test for starters.
Do not overlook the camchest area for any lifter/camshaft issues.
Scott
2014superglide
Engine Mechanical Topics
11
09-24-2017 07:31 AM
miketimer
18
01-07-2017 08:13 PM
Jimzhere
07-07-2014 05:56 AM
bamabadboy
02-11-2009 03:28 PM
strickrodt70
Ironhead
13
05-20-2007 08:16 PM
Quick Reply: Engine performance
