96 CI Heads vs. 103 CI Heads
What are the differences between the 2007 96" heads and the newer 103 heads other than front head motor mount hole and ACRs?
Are the combustion chambers the same size? Are the valves the same.
I am installing 103 jugs and pistons on a 2007 St Glide, and planned on using a SE-255 set of cams for low end grunt. That is where I ride. I am a heavy guy and want the low-end torque.
Cams and cylinders are installed along with lifters. Heads now have manual CRs. Ready to put them on but want to use the best head gasket thickness for the build. Pistons are down .006 & .007.
Trying to figure which head gasket to use while considering compression and squish. Which way do I need to go?
Started on this build thinking I had it figured out because there was a PCIII map with all components I am using. ???
What are the differences between the 2007 96" heads and the newer 103 heads other than front head motor mount hole and ACRs? Are the combustion chambers the same size? Are the valves the same.
I am installing 103 jugs and pistons on a 2007 St Glide, and planned on using a SE-255 set of cams for low end grunt. That is where I ride. I am a heavy guy and want the low-end torque. Cams and cylinders are installed along with lifters. Heads now have manual CRs. Ready to put them on but want to use the best head gasket thickness for the build. Pistons are down .006 & .007. Trying to figure which head gasket to use while considering compression and squish. Which way do I need to go?
Plated & Screwed (05-24-2016)
When i enter the 551s into the calculator my compression goes up even more. Why do you recommend those cams? I am trying to go the other way. Thanks!
128auto
06-22-2013 01:50 PM
