Re-using lifters on cam install
Old 05-18-2016 | 05:25 PM
stal94gt's Avatar
stal94gt
Default Re-using lifters on cam install
I just got in a set of cyclerama 575 cams off a member here (doc, a great person to work with) and I plan on re-using the stock push rods and was thinking I would be ok with the stock lifters as well. My night train has 16000 miles on it and runs great. I research I have seen is a little wishy washy on how long the lifters hold out. I am not going to do any more performance cause I am doing this cam swap simply to swap the bearings and add a little more fun to the bike. My choice in cam was decided cause I wanted more mid range power over peak rpm power. Any suggestions on the lifter issue will help me out a ton
Old 05-18-2016 | 05:41 PM
QC's Avatar
QC
A new set of better lifters can be had for less than $100.
Old 05-18-2016 | 05:43 PM
stal94gt's Avatar
stal94gt
Any suggestions?
Old 05-18-2016 | 05:46 PM
QC's Avatar
QC
Comp Cams 850-1 I believe is what some in here use if they don't go to S&S standards, which I used. Those were $115. The Comp Cams units are $80 or so.
Old 05-18-2016 | 06:22 PM
stal94gt's Avatar
stal94gt
Looked into the comp cams lifters and they look promising for a good replacement lifter. I will measure the base circle of the cams to see if they will work with the stock push rods. I am sure it will work
Old 05-18-2016 | 08:22 PM
djl's Avatar
djl
The lifters will work. The base circle is .020" smaller than stock, so they will work. Could be a little valve train noise but if so, you can always replace the stock pushrods with adjustables and run more preload.......
Old 05-18-2016 | 09:43 PM
stal94gt's Avatar
stal94gt
If the base circle is indeed .020 smaller than stock the oem push rods will work fine. As long as they hold pressure like they should I should not notice any valve noise
Old 05-19-2016 | 05:35 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I'd suspect that at 16,000 on the clock, the OE lifter will work.
Keep your ear open for noise upon start-up.
WE are a subscriber to an adjustable pushrod in order to load the lifter to .140".
That cam is not a noisy grind as a rule.
Installed another one 2 days ago in a 110".
Scott
Old 05-19-2016 | 09:24 AM
djl's Avatar
djl
That's the unknown with the OEM lifters and why adjustable pushrods may be required for a quiet valve train. The OP won't know until he tries the 575 cams with the OEM pushrods.
Old 05-19-2016 | 11:38 PM
stal94gt's Avatar
stal94gt
Since swapping lifters and rods is not a hard job I will try install new lifters to the comp 850-1 lifters and reuse the oem push rods.
Quick Reply: Re-using lifters on cam install
