110 bolt on kit w/ kompressor heads
Can they be reworked? If not, what's a good head choice for my set up? Currently have 2013 EGC- 103 being replaced through warranty w/ the 110 bolt on kit from the crank up. FuelMoto Headers w/ jackpot 4" mufflers, FM A/C, SE 585 cams
Time is critical due to build schedule.
Thanks.
Thanks.
Can they be reworked? If not, what's a good head choice for my set up? Currently have 2013 EGC- 103 being replaced through warranty w/ the 110 bolt on kit from the crank up. FuelMoto Headers w/ jackpot 4" mufflers, FM A/C, SE 585 cams. Time is critical due to build schedule. Thanks.
keno (05-02-2016)
I only have 2 choices at this time due to funds and time. I currently have the Kompressors at 10.5/1, but dealer said if I didn't want to use them, they would swap them for New set of Stock 103 heads at no charge and swap the Kompressor valves and springs to the 103 heads to bring it to 10 to 1 but I'd have to buy the push rods to fit. If it's an either or, what would you do? No time nor funds to have head reworked.
Thank you for any help.
I only have 2 choices at this time due to funds and time. I currently have the Kompressors at 10.5/1, but dealer said if I didn't want to use them, they would swap them for New set of Stock 103 heads at no charge and swap the Kompressor valves and springs to the 103 heads to bring it to 10 to 1 but I'd have to buy the push rods to fit. If it's an either or, what would you do? No time nor funds to have head reworked.Thank you for any help.
The head exchange seems fair even if the Kompressor head does cost about $70 more than an OEM 103" cylinder head, so you are giving up about $140 on the exchange. However, I am not sure why the valves and springs need to be changed since the OEM springs in the OEM 103" head will accommodate the lift of the SE585 cams. The parts manual does recommend the +.030" pushrods with the SE585 cams; they run about $95 from an online discount dealer and cheaper than a set of HD adjustables.
I think I would go back with a counter offer which would be to install the OEM 103" heads without the valve/spring swap (there may be some reason why the swap is necessary but I would like to hear it if I were you), so there would be no labor cost for the valve/spring swap. Also considering the difference in cost between the OEM head and the Kompressor heads, the dealer should include pushrods at no additional charge.
djl, they aren't charging me for the valve /spring swap. I don't know the reason for the swap either. I see the dealer tomorrow to give him a decision. So if it were you, you'd use the stock 103 un worked heads over the Kompressors right? What dyno numbers could I expect with this set up? 110 cylinders/pistons, 103 heads, se 585 cams, se a/c, FuelMoto's jackpot 2-1-2 headers w/ jackpot 4" mufflers?
I really appreciate your input!
djl, they aren't charging me for the valve /spring swap. I don't know the reason for the swap either. I see the dealer tomorrow to give him a decision. So if it were you, you'd use the stock 103 un worked heads over the Kompressors right? What dyno numbers could I expect with this set up? 110 cylinders/pistons, 103 heads, se 585 cams, se a/c, FuelMoto's jackpot 2-1-2 headers w/ jackpot 4" mufflers? I really appreciate your input!
keno (05-04-2016)
128auto
06-22-2013 01:50 PM
