103HO High flow stock air cleaner. Switch to another without tune?
So got a new 2016 Fatboy. With it having the 103HO and high flow air cleaner from the factory if i want to switch to another air cleaner like the Screaming eagle heavy breather elite or even a round style like inverted like what Arlen Ness sells so i have to retune? Or is it already tunes for high flow from the factory since it has the HO?
What about air cleaner +slip ons? And if i go full exhaust whats the best canned tuner out of like the DYNO MAX, V&H fuel pack, Power commander ect ect... For at home install. When i had my Night train i took it to Harley and added V&H Big shots and they tunes it. Wasnt really happy with the out come. A lot of decel popping and black smoke from the exhaust. Definitely ran rich. With all my other Harley i just did slip ons. Id like to do more this time around.
www.fuelmotousa.com they will pre load a tune for you based on what you install. You've been here for a while....are you just jerking our chain? Lol
Originally Posted by kishstl
The air will only flow as fast as it's most limiting part of the system and from the factory that is definitely the exhaust and cam.
Save the $$ for a replacement air filter and put the funds toward the purchase of a good fuel management system like the Power Vision or the TTS Mastertune. Replace the complete exhaust system with a system from Fuel Moto, Fullsac, V&H or Rinehart and get the motor dyno tuned. Just me but I would take the opportunity to drop in a set of cams like Cyclerama 575, Andrews 48, TTS150 or something similar and get the "Stage II" setup tuned. Could easily see 95HP/110TQ or better even with the OEM filter.........
Even if there was a difference, the only place it would show up would be at WOT and the difference would be negligible; hardly measurable and certainly not register on the butt dyno........
If I understand what you are saying but sounds like you are conflating velocity with flow?? The intake valve is the flow choke point and the filter make up, i.e., size and material as well as the throttle body can affect flow.
Since EFI is map-based rather than velocity-based (carb) there is very little influence in the a/f as long as it is not too restrictive. On the other hand, a carbed bike will show AFR change with the least bit of intake resistance.
Same question
I just bought a new 2017 Wide Glide with the 103 HO and stock high flow air intake....I'm looking for the same answer really, but not due to anything performance related, strictly ergonomics. The stock, oval shaped, filter hits my knee and it's hard to reach the rear brake, the Heavy Breather I am looking at getting is more forward and does not interfere with my leg at all. Since both are high flow filters, would it be a straight swap with no re-tuning?
Forgive me if that's a stupid question or if it's already been answered, but this is the first big Harley I've owned, after owning a few sporties, and have never done a stage 1 or bought one with it already done from factory.
