will a 103 Engine mount in the place of my 96
Old 03-18-2016 | 10:45 AM
Notgrownup's Avatar
Notgrownup
Default will a 103 Engine mount in the place of my 96
I have a 07 FLTHTC with a 96", will a 103 powerplant from newer bikes mount to my bike?
Old 03-18-2016 | 11:08 AM
djl's Avatar
djl
Yes; if an air cooled motor. The front motor mount/stabilizer is different on the later models but I believe the cases are the same and the later cases will mount up with the earlier front motor mount. that would be worth checking in to for verification as I am not absolutely sure. Water cooled will fit but I think you would have to use the heads from the 96".
Why not bore your cylinders to 103"? Or, have you considered the new 110" drop in cylinder/piston kit? More displacement, less work and probably cheaper than the cost of a 103" motor.
Notgrownup (03-18-2016)
Old 03-18-2016 | 01:33 PM
jkloeker's Avatar
jkloeker
If I was going to build up the 07 the first think I would do would be check the crank runout. I fee like 07 was a bad year for cranks, but I could be wrong.
Old 03-18-2016 | 01:42 PM
djl's Avatar
djl
'07 was the first year the MoCo outsourced the crank manufacture off shore and changed the runout spec for warranty purposes from .003" to .012". There were some quality issues the first year and there were some issues with '07 cranks at a higher incidence than later years as the quality bugs were worked out. So, the OPs crank runout is what it is and certainly worth checking, particularly if the OP is considering gear driven cams. However, there are plenty of '07 owners running performance motors with no issues.
Old 03-18-2016 | 07:17 PM
Notgrownup's Avatar
Notgrownup
Well I am toying with different scenarios ...at 91000 miles I don't trust my bottom end to build up to 107 but I might get me a 103 and just run this for a few years instead.
Old 03-18-2016 | 07:20 PM
prodrag1320's Avatar
prodrag1320
What year is the 103"? Would be cheaper just to bore your cylinders to 3.875",then yours is a 103"
Old 03-18-2016 | 09:53 PM
djl's Avatar
djl
Sounds like a great opportunity to me to pull the lower unit, have the crank serviced by Hoban Brothers (AKA Darkhorse), case bore for 4.125" cylinders and build a 117" motor. Don't know how much the 103 will cost but I would think comparison to building a 117"er would be worth a look.
Old 03-19-2016 | 06:52 AM
Notgrownup's Avatar
Notgrownup
Well looking around the web, it seems I can get a fairly low miles unit from $2000 all the way to $4000 for a brand new take out.....from what I can gather I will spend around $5000 to get my bottom end addressed and a 107 or 117 kit I installed. Dropping in a fairly new 103 would be easy and wouldn't give me much downtime. I am not looking a tire shredder, I just was a reliable power plant with a little more Ooomph than what I have
Old 03-19-2016 | 07:02 AM
prodrag1320
5000.00 to do your lower end and do a 107" ???? not sure who your asking,but ide run like hell!!!
Old 03-19-2016 | 07:09 AM
Notgrownup's Avatar
Notgrownup
Well Kirby, in all honesty and fairness, I haven't got any finalized quotes but it looks like it was going to be between $3800-$5200 depending how many cubic inches I would pick. I an cautiously optimistic I can do what I need fir a mild build on the lower end of that price.
Quick Reply: will a 103 Engine mount in the place of my 96
