Hylift Johnson lifter feed hole 90 degrees out
Ready to drop the new Hylift Johnson lifters in and I noticed the feed holes are 90 degrees out from the stock lifters I pulled out. Is this an issue or doesn't it matter where the hole is? Just checking before putting everything back together. Here's a couple pics. The new one is on the left.
I went through the same thing when I did my cams, lifters, etc.... the pros say it doesn't matter.
For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Okay, but since it's the service manual, I would think it would be,... oh I don't know,.. correct!! It's hard enough to figure out what I'm doing here without outdated info in the manual.
Service manual says "install lifters in the crankcase bores with the oil hole on the inboard side and the flats on the lifters facing forward and rearward". With the stock lifters, that's impossible to do, therefore incorrect and confusing to an inexperienced person. If it doesn't matter, it should say that.
