Lifter oil holes IN or OUT?
First off, my bike is a 2014 FXDF 103.
I recently did a cam swap and replaced the lifters with Comp Cams 850-1 parts. Now the bike is back together, it runs great, but I have a fairly loud tick/knock type noise that appears to be coming from the front cylinder - especially when the bike is cold.
i suspect incorrect pushrod adjustment or a bad lifter. Pushrods are S&S Quickee adjustable, so I will reset those and play around. Current setting is 4 turns plus 2 flats.
But I have a question on the lifters....
In my service manual it says to insert the lifters into their bores with the oil hole facing INBOARD - i.e. towards the cylinder. So this is what I did.
However - i also read a RedShift cams installation guide that says "make certain you have the oil feed hole in the lifter facing OUTWARDS"
So which should it be ????
Thanks, I couldn't really see how the orientation might make much of a difference, but that certainly puts my mind at rest.
I'll probably pull the lifters over the weekend and put the stock ones back in. If that quietens it then I'll know for sure its a lifter issue and replace them with something else...
Yep - I'll definitely try just adjusting the pushrods again first off....I hope that fixes it but I am prepared to replace lifters if that's the issue. It could also be the pushrod knocking on the pushrod tube itself...
You could have a pushrod rubbing on a tube, I just re-read your 1st post. The S&S are some chubby little bastards, there are others when have had issues with them rubbing.
and expands faster than the rocker shaft causing the shaft to rock back and forth against the hold down bolts.
:-) I already put Rocker Lockers in there when I put it back together......so I hope it's not that!
My question here is, how would I know? I guess look for witness marks on the pushrods when I pull them? Although I've only done around 50 miles on the bike since putting it back together, so probably not enough time to see anything.
I am using S&S pushrods and they were rubbing on the pushrod tubes so I used the top half of OEM tubes they are about an inch shorter and bottoms of S&S tubes so I can make adjustments that gives enough clearance for the collar not to rub.
